good OP AMP circuit
Hasnom
Hi! Everyone...
I got a project to make a circuitry using OP AMP. I am currently in 4th semester Electronic Engineering...
Kindly give me some good and different Ideas or circuits which I can make....
Dark activated switch
I just recently made a circuit using an op-amp as a comparator. One input i had a steady +5V and on the other input the voltage would change based on a photo resistor. When the photo resistor went below +5V the output of the op-amp would go high. This was then used to activate a transistor. I just made it turn on an LED but you can connect the transistor to whatever you would like. Ill try to put up a schematic tomorrow.
Thanks for the reply....
It will be great if you can put the schematic here...
What do you say about Light Listener?
Hi! Everyone...
Look at this pdf, it has a large number of useful circuits for OPA's.:)
  • OPAcollection1.pdf
