Boncuk
Hi Carl,
here is a circuit which operates at a stable frequency of 25.6KHz generated by a crystal oscillator of 3.2768MHz.
The voltage output is adjustable in a wide range.
Electric shocks are always dangerous. If somebody gets shocked using a heart beat electronic device the cables of which might catch on fire.
You might try building that circuit. Overvoltage protection is given by using 30V zener diodes across the power transistors to eliminate excessive output voltage caused by possible oscillations. (depending on PCB routing)
Additionally the output current is limited to ~27mA at 30V with the output pins shorted.
Try the circuit on yourself before you use it on others. Since the frequency is relatively high you might not feel a shock but suffer from high frequency burns.
I do not take any responibility for harmful applications.
To audioguru: Muscle stimulators were never intended to build up muscles. They have been designed to do what they are supposed to do - stimulating muscles. They are used for patients suffering from e.g. a traffic accident having had an arm or a leg bandaged for a long time period.
Boncuk
Boncuk
