Unfortunately I don't have any solution for this problem.
This problem is written here:
:: EPE Chat Zone *:: *Radio Bygones Message Board ::: LCF meter
I think it's a problem with the firmware adaptation from 628 to 628A.
But maybe I know the reason for that:
When the LCF meter first starts it will store the default frequency values to the EEPROM, and the second start it tries to read them.
So I think there is a problem with a EEPROM handling with the 628A source code. (628 and 628A have differences in EEPROM HW)
Try to start up while pressing the Nulling button, it will enter the correction subroutine you can set a number (0-100%) (check the article) and it would store the result in EEPROM, so set the number, SW off, turn back in while pressing the NULL button and check that is the number stored. (not 100 like normally).
If the problem is not with the EEPROM, than we could put some line in the source code so it will start up in inductance mode.
Eliminating this error.
I'm just planning to build this LCF meter.
You can't measure a cap in circuit! You have to solder out to get an accurate read.
And you have to keep the measuring wires SHORT!
Not like in the original article (crocodile clips
You can use ESR incircuit with power off.
The best way is to put 2 female banana sockets on the instrument.
It would be awesome to ad an ESR meter to the CLF (but it would be very complicated I think)
And It is not really necessary for hobby, it's for pro servicing.
I really don't like that the Ext. Freq input is not isolated from the MCU and it's just for 5V TTL. I will do some modification to that (like transistor isolation...)
How accurate is this devices with 100nF ceramic caps?
