help to find a relay equivalent
24vdc!
I mean a store where I can find it, I only find this type of relay in China, so I doubt its quality, that's why I look for some other options
It's a "Four pole cradle relay", PCB pins with a 12V coil, from what you say.
Something like this should be fine:
Or you could fit a socket and use the commoner plug-in style:
The plug-in style are extremely common, from many makers; direct PCB pin are available but much less choice.
Any big electronics supplier or distributor should have the ones above or equivalents; eg. the Omron plug-in one from Mouser:
The PCB pin one, on ebay:
That's the one, as far as I can tell; three pole, PCB pins, 12V DC coil.
You can verify the pin spacing against your original, from the data sheet.
