I found this type of amplifier to be slow. (not good for 300khz)i think this may be closer to what you are looking for, the rest of the article is here... **broken link removed**
Its an amplifier to power a magnet, on a sensor used on oilrigs (im sorry i cant be more specific, but its most likely confidential), (Im guessing oilrigs can output the ammount of current that i need - in anycase that part really isnt my problem - I've just been given specifications). The signal is a pulse (a sync looking pulse), so its not going to be on for very long... So I dont really have to worry about it overheating. 95% of the time it works at 330kHz - but sometimes they do use it at lower frequencey's.
30 posts and i still see no well defined set of specifications. if the frequency range is known (not just upper frequency of 330kHz) you may not need high voltage amp. perhaps you could use transformer to step it up for load, but the primary could be lower (at higer current of course).
For us who are trying to help it would be very beneficial to know what the 5 ohm load is that needs a 330Khz input.
Without knowing what the load is what it works with and how it works its nearly impossible to know what type of power system to deign for.
Is it a 5 ohm inductive impedance, a capacitive load like a piezo electric device, a pure restive load, phase and waveform sensitive load, a LF RF antennae load, etc.
