Done, fully recapped. R41 and Rbonus were replaced with 8k resistors, all I had underhand was 8 or 20k...Recap it and get it over with especially C16
V = 0VMeasure V across R38 in the OFF position.
V = 0V, in both ON and OFF positions. interestingly, the LED did not turn green when switched to ON, with C16 shorted...With no signal. Short C16 and measure V across R41
Hard to estimate, I'd say 0.5-1 sec.Check delay to LED change from OFF to ON.
I'd say a good couple of seconds here, longer than OFF-ON change.Move switch to AUTO.
Apply music. Check delay to LED change.
I'm just confused as to why ON wouldn't show a green LED with C16 shorted?! Expected?R43 and the internal leakage current of C16 allows the timing circuit to discharge when the mains are cut. At 5RC, the cap is about 99% discharged. I can fix that with a J174 FET and a resistor. The resistor across the cut must be used too.
I'm off to Paris on sat, south of france on wednesday, spain on Friday.... Then I have a few days of work, and I'm off to Italy for a few days... Next few weeks will be a bit more on and off so I'm trying to speed things up, or at least stop somewhere reasonable! Can't complain about holidays though...That ought to keep you busy for a while.
