R9, R11, R12 not good;
(D2+R5) =
(R8) =
Make sure Q2 isn't in backwards.
(D2+R5) =
(R8) =
Remember, the amps has to be ON.
Q2, D2 or R5 has to be bad. I'll bet Q2. Maybe put the last batch back that worked and forget about matching.
Mmm. I can't seem to remember anything. While sleeping, I forgot about an issue. The biasing on Q7 will NOT be present UNLESS C4 is shorted. That's how they get away with not using a pot for a bias adjustment. Sorry about that.
So, check the voltage across Q7 and the variability with the new pot with C4 shorted.
I'm busier right now too. How about quickly putting the outputs in; setting R(whatever) so it's 3.6K (memory) and basically see if it functions. Look at E-C with signal, but no speaker.
OK, saw your post. I'll be busy for the next couple of days. I'll have to get back into the swing of things myself.
So, at this point everything is supposedly complete, but not working? What mods are in place?
What's that voltage between the two bases (the bases that have been been shorted together)?
Check the resistance of the speaker?
