Doesn't that Metal or plastic bushing make the contact? with the sleeve to the mounting surface?
I thought i was the bushing that made the control with the sleeve to the mount surface
How can a plastic bushing make the sleeve to the mount surface to be grounded to chassis? it's plastic , so it will always be isolated right?
Ok...I think you are over thinking this...
All panel mounted jacks are designed to be electrically isolated or non-isolated from the chassis when mounted. If the jack has a metal bushing (the barrel of the jack that the nut goes onto) and it comes in contact with the panel mounting surface, it is designed to be a non-isolated jack. Now as I mentioned in an earlier message, I've seen this non-isolation circumvented by placing a non-conductive washer in the panel hole to isolated the jack.
![facepalm :facepalm: :facepalm:](/styles/default/xenforo/smilies/facepalm.png)
If the same type of jack has a plastic barrel, usually inside the plastic barrel is an additional metal barrel that makes contact with the sleeve. This is designed to be an isolated jack.
Now I've also seen where the isolation is circumvented by wiring the lug, that connects to the sleeve, to a panel mounted screw..
If there is any uncertainty, you can mount the jack check for continuity between the sleeve and the chassis with an ohm meter.
BTW-I have a couple of Peavey Bass AMPs, are you trying to replace the jacks in a peavey?
eT
