mvs sarma
I did substitute C5 with a 10uf. The 2N7000 has its terminals correctly(checked using the diode). As for the BS250P it got damaged and now there is a short between its drain and source( I imported it and it is not available here normally). Is there any other MOSFET i can use?.Did the .1uf (ceramic) cap also. Since i am going to make the PCB again i want to know what inconsistencies have i done except the ones that you have already stated so i can correct them.I am making a new one to make every thing clear and systematic. Thanks.
You should run the troubleshooting run and check whether you get the Vdd and Vpp as indicated therein. after that only it is better to program a chip.
