Well if VPP is fine (and it appears it is) then test the VPP run (+5) & reset (Gnd) modes (also in troubleshooting)
Around 28 megohms on mine.What should the resistance be between pin 20 on the 18F2550 and pin 23?
Mine agrees with Futz.
Can you explain how you work out from the schematic? I've obviously got that bit wrong and it would be good to know why
However.. the fact that I get virtually no resistance suggests that there might be a short somewhere. It could be where I think there is a fault on the PCB, I'll try and get a picture.
He He. You read that prior to me nuking the bit about the schematic. There are so many poeple here who know more about this then me that it makes no sense for me speculate. I am a CS type by training.Can you explain how you work out from the schematic? I've obviously got that bit wrong and it would be good to know why
Remove U1 and measure again without power being applied, if the measured resistance is still a few ohms, I would agree with you in that you have a short on the board. If the resistance is no longer only a few ohms, measure the pins on U1 for a possible short![]()
Thats a copper track bridge for sure, use a small scalpel blade to cut the bridge.
Where do you think the other one may be?
The new Junebug manual shows the orientation of both BS250 types.
