SABER.MAHDAVIFAR
Hello. This is a Hardstone brand microwave oven board. It had a power failure problem. The power supply was broken and the power problem was solved by replacing the switching IC. The 12 and 5 voltages are OK. Now the device does not turn on when the power button is pressed. I tested the power pins of the display board ICs, which are the microcontroller and LED driver, and they all have voltage and none are shorted. Why does the device not turn on? How can I test the microcontroller other than by testing the voltage? Thanks.
18:41
18:41
