The picture looks like one actuator for one door. There has to be an actuator in each door. It's likely that all of the actuators are tied together AND that there are two relays that activates lock and unlock especially since the alarm that broke is aftermarket too.
You need to figure out what you have and how it;s wired. The original alarm and even the new alarm could have relays internal. That, so far,, we can't help you with.
The assumptions we are making is that you get a contact closure to ground either from a resistor or transistor for either 0.5 or 3.5 seconds.
We don't know what kind of sinking current the alarm can support.
Evidently, the wiring is there. The questions are:
a) Is, is the wiring attached to the motors or a relay. My guess at this point, there are two relays somewhere and an actuator in each door.
Not sure if you have an interior lock button?
Your orange wire and your orange/white wire should connect to ground for either 0.5 or 3.5 s depending on the jumper for a lock/unlock command.
I'm nearly 99% positive you need a variant of Les's circuit somewhere and it may already exist.
If the existing wires go to the motors, you will need Les's circuit.
The actuator motor is essentially a 2-wire motor where you have to reverse the polarity to change the state. Those two relays allow you to do that. They short out the motor at rest which by the way causes an instantaneous stop and they use a lock signal and an unlock signal in the form of a contact closure to ground.
You apparently have the wiring in place. 10 AWG is probably too thick.
