The arduino Fio device you mentioned, it doesn't have wireless cpability on its own does it? Am i right in thinking it requires something like the xbee module to give it the wireless ability??
That is correct.
I was thinking of a simple interface with the two way radio that has a external mic that has a PTT switch.
Use one of the digital outputs to key the radio up and one of the PWD pins to generate a audio tone.
and one of the Digital inputs to monitor the float switch. and use a simple audio tone pulse like one pulse per second for gen 1 and two pulses per second for gen #2 ext
This is really simple! Is the tank under pressure or does it vent to the atmosphere?
If vented like I suspect because the fuel is non-volatile fuel oil, just install a liquid pressure sensor on the pipe coming out of the bottom of the tank. The pressure will vary with the height of the contents in the tank.
If the tank is under pressure, mount a pressure sensor on the pipe coming out of the top of the tank also. Measure the differential pressure between top and bottom and get the same result.
Gravity is your friend.
Or, if this is a power generator set for an outdoor concert, surely the event is important enough that you could afford to hire someone to babysit the genset and check the fuel level with a stick if necessary so that no problems arise.
