Mikebits
The only questions I have about it are..
1. how sensitive is the adjustement? do you think it is as sensitive as the other kind of dimmer?
2. Could I get some little switch to cut the power off to the dimmer? One of the good things about the other set up is it has the momentary switch that allows you turn the whole thing off and on... this allows you to turn it off and one easily without changing the adjustment level of the heat..
Question 1. Dunno, try one out and see. $15.00 to find out
Question 2. Pull the plug, or plug the thing into a receptacle that is controlled by a lightswitch.
