BirdsInMyBrain
Hello! I want to repair two solar light strings. One has 120 blue LEDs and the other has 200 blue LEDs. The solar panels of both look fine and the light strings have never even been outdoors because they stopped working when I "tested" them ((covered the solar panel, Heh!
)) I did of course try fresh batteries with no success.
Looking at the "innards", it looks to me like they were assembled using crappy hair-thin wires and even crappier soldering.
So then, my questions are this:
Should I try to disassemble the existing mess, strip the wires, clean up the mini-boards, and resolder? ((I've never soldered electronics, but I do very small stained glass items and I'm sure that adapting won't be too problematic.)) I have some solder that's called "waterproof silver solder", which I think has some copper in it as well; I also have some lead-free zinc solder, and some of the typical lead:zinc stuff.
*OR*
Would it be better to try to find new controllers? If so, should I switch the strings over to lithium batteries ((I'm looking at Amazon - yeah, I know, not the best but it's a place to start...)) since there seems to be a wider variety of those? Or if I want to be able to use the replacement NiMH bateries I just recently bought <!>, do I need to consider anything other than the voltage...? I'm sure the LEDs are connected in series, since the strings *do* use one 1.2V rechargable battery, but I don't know whether there is any limit on the mA that the simple charge-controller modules can put out. The whole reason I got these 2 strings was the length, since I want to suspend them over the pool and deck, which comes to at least 42 feet between where I can stick support poles into the ground.
I know I could switch to plug-in lights, but the lawn people ((my mobility is quite restricted so I can't do my own any more)) are so darned careless that I *much* prefer to not deal with electrical cords across the mowable areas![nailbiting :nailbiting: :nailbiting:](/styles/default/xenforo/smilies/nailbiting.png)
I also know I could buy new strings, but being on a fixed income now, that just gets annoying.
MORE than that, it's a matter of principle at this point: I much prefer to learn how to repair what I've got, than continually throw money at sloppy manufacturers. Ideally, I'd like to learn to build my own from scratch, but for now, I would be thankful for any and all possible repair suggestons![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks for reading!![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
*OR*
Thanks for reading!
