I'm working on the power supply in a Toshiba TV (TP4688J) and have found that the 5v supply, from an L78MR05 (Q840) is slightly high--5.27v--at both the output pins. As I read the datasheet, max output is supposed to be 5.2 Vo1, or 5.25 at Vo2.
Is that .07v enough to make a difference? (It's apparently been replaced at least once in the past.) Or should I look further to explain my dead power supply? (I know there is a leaking cap off VR Q801 but haven't found anything else).
Thanks.
Thanks.
