pass the TIME away
Something that might cause some confusion when working with negative numbers....
It's easy to understand that 5 is less than 10.....
but it's easy to slip up with negative numbers.
–5 is greater than –10.
I realize that
it wouldn't output the correct value of MS
I got that section worked out where it exits each section correctly.
Been working on pcboard to fit desired enclosure.
All the code, or most of it works as planned. Pcboard layout won't have an effect on the code or verisa
