ecestudent
The rectifier diodes?![]()
Oh yeah... I forgot that very important stage... He3.. Thnx..
I'll check if 22-0-22 is available. when i used a 12-12 i did get above 30. Anyway in case the 22-0-22 is not available, i'll just adjust the resistor values to give me 30V.
The datasheet for the TDA7295 is confusing.Am I supposed to supply some voltage to the mute and standby pins?
The circuit in the datasheet shows the Mute and Standby pins having capacitors to pin1 which is grounded and series 22k resistors to a positive voltage that is not specified. The positive supply might be OK.I think the mute and stndby pins need some voltage above 3.5V so that they won't be in mute and standby... Would the +35V be ok for that?
Don't you have its datasheet?Is the tda7295 suppose to gain heat when it's operating?
