Ha Ha. I'm still working on the amp. I got a whole 3 watts so far. I'll let you know.
Is that 3W of carrier leakage, or 3W of modulation?
My criteria is an attentive well trained ear and eyes. My equipment is cheap as they come. a 40MHz scope and a voltmeter and any signal generator is an oscillator built by muy and homebrew receiver.Originally Posted by Mikebits
What is your criterion for working great? What sort of test equipment have you used to verify your circuit?
How do you know this without a spectrum analyzer or equivalent equipment? I'm sure your alien ears cannot hear all the way up to 300Mhz. How can you have "over modulation" of SSB without clipping and how can you have clipping without spurious emissions? Maybe now is the time to add an ALC circuit to the mix.Space Varmint said:Well, change that. It's now 5 watts of clean output. No spurious emissions with even over modulation. If the is no audio in I cannot see any carrier on the scope or pick it up on my receiver.
So you are not over modulating then?I got the audio gain backed down to where you literally have to scream in the mike to clip.
I think - in the correctly wired marriage of a "ballanced modulator + filter" system, there is not much of the carrier to speak about and it is well outside of the filter's passband.
Yeah.He said my signal was jumping around a little and sort of distorted
This is where your BFO does come in - in CW, and it is very much xtall locked on SSB..
