Oh really? Oxygen is not explosive? When Katrina hit and there was a bus load of patients on oxygen tanks, why did they burn up? Lets see have you ever taken a match to a room or container full of pure oxygen? You know I am not going to go any further with this as you seem to think you know it all yourself. […] All it takes is a spark to ignite it.
Oxygen doesn’t burn – it makes things burn more intensely. When you take a lit match to a container or room full of oxygen, the flame will burn bigger and brighter. That’s all. This isn’t the oxygen burning, but rather the wax burning more intensely.
No, I don’t know it all myself, but clearly, I know more than you.
As I said you guys are out to make it look like you know everything.
No, we’re just correcting you where you’re wrong. When you get everything wrong, expect to be corrected on everything.
I am sure you are atheist or you would not say what you said about God and His Creations Below.
That doesn’t follow.
Oxygen is very flammable or it would say it is a inert gas on the tanks. A flame can not even exist without Oxygen which means it feed the flames.
Wrong. Only the “noble” gases are truly inert. Other elements are reactive, just to different degrees. And whether the inert gases should be labeled as such on the tanks is debatable, since they’re harmless.
Oxygen is not flammable, and any oxygen tank that says it’s flammable is wrong. It’s an
oxidizing agent and should be labeled as such.
But apparently you know it all. I am not wasting my time here with this discussion you raise. This is arguing and it is not working together. I am trying to find smart people who want to work together on this.
It doesn’t work.…
So which industry are you plugging for? Power, Oil, Pharmaceutical, FDA. Federal Government agencies, Chemical Manufacturers and Etc.? Who is paying you to say these things? Or are you like many others who think they know everything and like to criticize everyone else so they can feel larger than life?
None of the above. False dichotomy.
I have read where someone even had a car running on the combustion of Oxygen alone once.
Either you were lied to or you misunderstood. Oxygen does not burn. It’s really that simple.
I have also read where water an run a car also buy itself and one guy in Australia did it with a regular garden hose I saw about a year ago on U-Tube. He did not even split the water. I do not know how or any of the details but I saw it working fine even though it was a bit rough. He said it had to do with the timing. I do not know if it is true or not, but I know that it is possible.
- Water doesn’t burn either.
- Do you believe everything you watch on TV? No, of course not. Now keep in mind that YouTube doesn’t have any of the checks and balances that broadcast TV does. So if you believe everything you see on YouTube then I have a bridge in New York I’m willing to sell you.
Anything, if done right, is possible.
That’s not true. Many things are just plain impossible.
Oh and it is in the New King James Version as a Example of people removing God's true name at Psalms 83:18 that is in the Older Gideon Bibles that used the King James Version, not this new one. They removed Jehovah from the bibles! So you can not call on his name for salvation if you do not know it. Have fun with yourself.
Okay, so now, what the heck does this have to do with anything we’re talking about? Are you saying that there’s some kind of atheist conspiracy behind the NKJV?
I will not be addressing the rest with you as you did not get the start of it right to begin with and you can criticize me all you like from here out but I am showing you what I Learned. I do not need to reference anything and as far as Abner Doble I have been researching his car since the 90's. What do you know about it? Little to nothing I suppose.
True. All I know at this point is it was a steam-engine car. By steam engine I mean similar to what trains of the time used.
Interesting, but not exactly relevant to the discussion.…
Most of what I Learned is disappearing off the Net so you better hurry. In fact a lot of things I learned is disappearing off the net these days.
Nope. The water car scam sites are actually proliferating.
Someone it working to hide technology.
Conspiracy theories?
For example Find a 12Volt Powered Neon Power Supply that puts out High Voltage (Around 2,000) with low amps at close to 42K Hz and is around $50 to $75. Fry's Electronics use to sell them. No one does these days. They are prefect off the shelf units that can be worked to over to use in this HHO unit like Meyers. I looked all over for the one like Tad Johnson described and it can not be found.
Could it possibly be that something else has replaced them for their intended use? Nah, there’s no such thing as Occam’s Razor in your world, is there?
I do not even have time to edit this again. See you later! This thing tells me to lengthen this message about 10 character and I do and then it tells me to do it again. How come I can not submit this? It did it again right after this.
Because you’re doing it wrong. You’re trying to reply inside my quote tags and write nothing outside.
Oh Really? Water is HHO and at a certain temperature it can bust the atomic bonds and become combustible itself. I do not remember the temperature but I have read this.
Water isn’t HHO. It’s HOH. When you break the atomic bonds (by whatever means) it isn’t water anymore.
