suitable amplifier type to power LO ports
yefj
Hello ,I need to choose an amplifier to power an LO port of two mixers with 17dBm power level at 10GHz without he following datasheets:
for this purpose I need to choose and amplifier with at least P1dB of 21dBm .
one amplifier is VGA (voltage regulated gain amplifier) and the other is a driver type.
What does it mean driver type amplifier does it fit to power the LO ports of my mixers?
mixers:
MM1-0320HSM-2_GaAs Double-Balanced Mixer
The MM1-0320HSM is a passive GaAs double balanced MMIC mixer suitable for both up and down-conversion applications. As with all Marki Microwave mixers, it features excellent conversion loss, isolation and spurious performance across a broad bandwidth and in a small form factor. The MM1-0320HSM...
markimicrowave.com
markimicrowave.com
https://www.custommmic.com/resources/cmd258c4_ver_1.0_1017.pdf
amplifiers:
1. VGA type
http://www.analog.com/media/en/technical-documentation/data-sheets/hmc996.pdf
2.driver type
http://www.analog.com/media/en/technical-documentation/data-sheets/hmc608.pdf
C608 is enough for for powering the LO port of your MM1-0320HSM mixers at 10 GHz with a 17 dBm power level. You should go for C996 only if you need adjustable gain. Otherwise, go for C608.
"Driver" has many meanings, depending on context.
The 608 is a power amplifier with 50 Ohm output; that's just what need, from what I can see??
Hello,suppose I am driving the LO of the mixer below with the amplifier below, so the LO will get the desired 17dBm.
The mixer is down converting withe RF signal of 10GHz -60 dBm
for 17dBm LO power is -7 conversion loss.
The issue is noise I know there are some elements
1. -174
2. NF of the mixer is 0.5dB
"mixer Noise Figure typically measures within 0.5 dB of conversion loss for IF frequencies greater than 5 MHz."
3.noise conversion from different bands
4.4. LO phase noise degradation.
How do I combine them to make the output noise in dB/Hz units?
Amplifier:
Mixer:
