suitable microphone to trigger an adjustable level
danrogers
hi all, i need to find a microphone for my project. I want the microphone output to be compared with an adjustable level, and if the microphones output is higher i want that to trigger my rf transmitter.
Ive spoken to someone on here breifly about it before and they suggested using some T072's for amplifying and comparing the signal from the microphone.
I have looked but im really not sure what type of microphone i will need? it must be fairly small.
thanks in advance if anyone can help :)
I used very small electret mics from broken cell phones for two of my projects.
thanks :) ive just been looking on farnel and they have quite a few. how would i know what will work with my application?
Im not sure how thwy work to be honest. Do you feed a voltage in then the vibrations they pick up correspond to vary the output voltage?
An electret mic has a microphone diaphragm and a backplate with a 48V charge attached permanently. The small capacitance between them creates a small variable voltage divider that is buffered by a Jfet transistor. The Jfet transistor must be powered from a few volts at about 0.5mA.
so basically i would need something like a 3v supply for it?
A TL071 single opamp and a TL072 dual opamp are low noise, have low distortion and are wideband. they were used in many hi-fi systems for the last 30 years. their minimum supply voltage is 7V.
there are newer low noise, low distortion and wideband opamps that work with a supply as low as 3v.
Here is my electret mic preamp circuit:
Hi AG,
This is another excellent circuit you often have reason to post, so I've added it to your other opamp circuit in the sticky at the top of this forum.
of course, sorry im really inexperienced with these types of audio circuits!
so how does the feedback come from the mic? or does it measure the voltage drop getting pulled to ground through it?
i hope that makes sense
The mic has a metalized membrane that is vibrated by sounds. The membrane or the backplate is permanently charged with 48VDC using electret material and the membrane forms a variable capacitor voltage divider. The variable voltage from the membrane feeds a Jfet transistor inside the mic that is powered by the 10k resistor in the preamp circuit.
The mic will produce acoustical feedback howling if it hears its output from a speaker nearby.
Thanks alot, they really helps me to understand it better.
what is the purpose of the VR in the circuit?
also, I want to be able to use a adjustable level output to trigger an RF module to send. what other bits of audio processing might i need to make that work?
VR is the gain control. It adjusts the sensitivity to sound level.
i see, thanks thats really helpfull.
Do you happen to have any idea how much power in volts the circuit would output?
thanks again
With a 9V supply, a TL071 opamp clips (severe distortion) when its output is about 3.3V peak or 2.3V RMS.
ok thanks, im wondering if that would be high enough to trip a relay or something similar, to trigger my rf module.
any suggestions on that?
thanks for your help and time :)
A relay is turned on and turned off, not tripped. A relay is driven with DC but the output of the preamp is AC audio.
Your RF module also might be turned on (not triggered) with DC, not AC audio.
The output of the preamp can be rectified, filtered and amplified to produce DC.
