I have been sitting back, reading, frowning & drowning myself with multiple complex issues from a beginners point of view & I am learning bit by bit how much I don't know once again.
In engineering often the most simple basic designs are the best so I just wanted to throw this at you to see if it covers what is needed to do the job but maybe without the complexity.
I realise we need a nice stable power supply which we have talked about & I will build.
Also reading the sensor ratiometricly using the Reference pin which I should be able to do.
This leaves the question about either:
Reference voltages (set points) but as you say these can be the cause of errors & not really required.
So instead of BCD Switches or Rotary encoders etc etc.
Can't I just use a 12 digit numerical Keypad, that way I can just easily select say 20 for 20" of water pressure or whatever, it does away with external reference issues & I should be able to work it out in the sketch. It would simplify things, it may seem basic but the end results should be just as good, I can't see any issues?
Maybe I am wrong of course, I don't mind trying a more complex way but my question is does this really need to be complex?
Basically if I press Number 5 on the keypad I just need to calibrate the output to give me 5" of water pressure.
Just a thought?
What do you think?
Cheers
Just a thought?
What do you think?
Cheers
