Three phase inverter from PWM
callkalpa
I am developing a three phase inverter using PWM signals from a PIC (18F452). The PWM signal will be used to fire the IGBTs. For the three phase inverter I need three PWM signals each with a phase shift of 120 degrees to fire the three sets of IGBTs. It is possible to get one PWM signal with the PIC.
Is there a way by which (by programming the PIC or using some additional electronic devices) I can use a single PWM signal and get three PWM signals each with a 120 degree phase shift? Or do I have to use a PIC with three CCP modules?
Thanks in advance
120 phase shift at what frequency?
I don't see any way of getting the three PWMs from one CCP module. You could, of course, bit-bang three port pins in software to get the respective PWM outputs.
