Reckon is a common word in the UK as well.
My location is clearly mentioned in my profile and displayed next to my name unless you thought I was in New England but that's the north not the south.![]()
Did any of you read the .pdf on the item?
https://www.electro-tech-online.com/custompdfs/2008/09/TRIPP-LITE_POWER-PRODUCTS_5752502PDF-1.pdf
At numerous points of the description it states "complete line isolation". A bonded neutral with an isolated ground should render the secondary as being isolated from the primary. If this is so I would suspect something is wrong with the unit. Tripp-Lite produces high quality items and they stand behind their products, in my experience.
Well, UL evidently stands behind them also. To me, and maybe my thinkings off here, earth ground and neutral secondary are not part of the primary windings. Would this not be isolation? I read the .pdf and it clearly notes the N-G bond. As does every other article I've come across.
I've no idea what it's supposed to be for?, it sounds pretty pointless?.
An isolation transformer as I understand it (and as he wants) provides a completely isolated secondary, so the item plugged in to it floats away from earth. This is for safety reasons, and means you can't get a shock to earth, and it allows you to use earthed test equipment.
Everything I have read indicates the secondary neutral is tied to earth groung for safety reasons. This give the current a place to go. Now I would tend to agree with you. This is not how I remember isolation transformers being constructed either. There was no ground connected to the primary side. I don't know if you had a chance to read the below article that I posted earlier but here it is. Tell me what you think about the N-G bond.
https://www.electro-tech-online.com/custompdfs/2008/09/mw20ng20article-2.pdf
The problem is that the words "isolation transformer" are used to describe to diferent things:
>> An isolation transformes to give an "isolated" enviroment so you can service line operated devices, use grounded test equipment, etc. (This is what most of us are thinking when we say isolation transformer)
>> A surge protector used to power sensitive equipment (computers), and that happens to be a transformer. They call it "isolation transformer" because it isolates the load from the line's noise, but it doesn't provide earth isolation.çç
Bonding the neutral is both good and bad.Everything I have read indicates the secondary neutral is tied to earth groung for safety reasons. This give the current a place to go.
Grounding philosophy is interesting reading, but unrelated to Speakerguy79's original objective. Speakerguy79 wants a transformer that allows him to operate a device without a ground reference. Many off-line devices make this a concern, because their 'ground' of its power supply is otherwise at something like -165V.
Is such a device currently available? Can his existing unit be converted?
If there is, I haven't found any.
Yes, they do exactly what he wants, they're medical grade isolation transformers as I mentioned above.
They're very expensive though, much cheaper non-medical isolation transformers designed for test benches and building sites can be found.
What's a DUT?
Device Under TestWhat's a DUT?
As far as I'm aware, the general practice is to leave the case of the device unearthed but if they're multiple devices connected to the same transformer, their chassis should be bonded together, to ensure they're at the same potential.
