wish to learn microcontroller....... need your help
Try this little bit of code for starters
I'm writing the program, but actually what means by : org, setb, seta, inc etc???/ suppose they are commands but what they stand for or what they do??:confused::confused::confused:
i'm not understand this....
You need to toggle P2.0 by inserting directly into the SFR window at
the bottom of the screen
I wrote the program in the simulator...
yes. it's working. LEDs are blinking......
That was a nice tutorial for beginner. Are you going to add in lessons and chapters as time goes on and publish it as a full tutorial ?
I don't mind to become another beginner to relearn 8051 from fresh as I have forgotten most of them already. My old 8051 board has a monitor program inside and communicate with the PC via COM port. I used the ASM51 and MSKermit to talk to the 8051 board.
Allen
I think ( Its my opinion ) that the paged memory is the biggest issue on the PIC.. ( I'm talking mainly about the 8 bit systems)
Im with you there Ian, The paged memory is my biggest gripe about the PIC's
Allen
I have done one for the PIC using MPLAB... I will do a tutorial eventually if its what people want..
Hello Ian,
what the code you posted last day is working on simulation.
Sorry!! I don't understand?
i want to say that : the code or program you posted in pdf file for me as a tutorial, is working in the simulator.....
Oh good... Tell me what you want to do next... I'll try and give you a lift up!!
thanks. next i want:: what is BIT ADDRESSABLE MEMORY.
what can it do exactly. i'm little confused in here.
can we only write a program only in rom?
Bit addressable are SFR's locatioons 0x80 to 0xF0 and a small 16 byte memory locations 0x20 to 0x2F.
Bit access is great for boolean flags on/off variables..
flags equ 0x20
   setb   flags.0 ; access bit 0 of the flags variable
plz correct me :
setb  24h
does that mean if I write this, the value of 24h is becomes 1 (high). and if I can access this 24h to the pin of micro P1.0 then the value of the P1.0 becomes . Am I right????
what does it mean by? truly I'm really can't understand this... As far as I know the bit addressable memory and the SFR has their own different locations.. some registers are bit addressable?????????:confused::confused::confused::confused:
im totaly lost here......
Bit addressing only means you can access a single bit in a byte
ie...
flag   equ   24
   mov   flag,#0xFF   ; move 0xFF into flags <<-- byte addressing
   clr    flag     ; clear flags
   setb   flag.1   ;  set bit 1 in flags <<-- Bit addressing
Now what will be next for???
I'm now reading the SFR in the dpdf.....
Hi Ian,
is there anything to have a look for me... ?:confused:
I want to make lighten up 8 LEDs in different way. And also want to understand the CODE/Program, how it works... thanks in advanced....:)
