Oh no, bauxite shortage panic! We'll have to start recycling aluminium or something drastic like that!
The UK have been recycling aluminium for at least the last 20 years.
Bauxite is the most common mineral in the Earth's crust.
Wikipedia said:Although aluminium demand is rapidly increasing, known reserves of its bauxite ore are sufficient to meet the worldwide demands for aluminium for many centuries.
You obviously didn't have your sarcasm radar switched on yet, Eric...
i think you have it on the 800W bulb case.
Aluminum is a fairly reactive element, which greatly implies free radicals. And free radicals are presumed to be one of the main causes of things like cancer and ageing and so on. That being said, everything is a "chemical", and pretty much all chemicals go through an intermediate state where they exist as a free radical. So, from this distortion of common sense it really could be logically concluded that everything does actually cause cancer, and you should stay away from it all.
My personal favorite is that the sun causes cancer, that has always helped me get out of doing yard work on hot days
Seems like you are grasping at any straw you can find to defend your isotera system and not gaining a single supporter or supporting fact for it.
It is the only lighting system in the world that needs no contactor.
What is that thing that the lamp attaches to? Looks like a connector?
.....i'd like to see anyone suddenly unplug a connector thats carrying 10 Amps.....BANG!
42V automobile bus failed because above about 28V, switchs and connectors start needing to be seriously expensive if contactor sparking and corrosion is to be avoided....so youll need your isotera icoupler to couple the energy to your flat battery.................effortlessly fitted, -no huge great plugs needed which small women will have difficulty yanking out of the wall socket.....single handed because you have to use the other hand to hold open the contactor lock.
My golf cart is 48 volts at 15 amps and my wife at 5' 2" & 100 pounds has no trouble with the 3 wire plug.
....yes but theres no need to disconnect that if you want to take the luminaire away and attach it somewhere else.....the connector that you speak of just connects once and thats that.....you never have to hot plug that.What is that thing that the lamp attaches to? Looks like a connector?
42V automobile bus failed because above about 28V, switches and connectors start needing to be seriously expensive if contactor sparking and corrosion is to be avoided
As far as isotera winning I don't even see them being in the game really
Either You're grasping at straws here or you assume that everyone else in the world has less lighting and electrical knowledge/experience and search engine usage skills than you
June 24th 2013
Cambridge-based lighting network company Isotera has closed a £1.6m second funding round to advance its business from product launch to volume sales. Isotera’s intelligent LED lighting system revolutionises the way in which ultra-efficient lighting systems are installed, lowering Capital expenditure as well as Operating expenditure thus accelerating the adoption of LED lighting and automated lighting controls. The system’s architecture is ideally suited for low cost communication purposes throughout buildings, allowing the expansion of its functionality beyond lighting.
the OP has unflinching faith in the product, and no amount of evidence or arguments will sway his opinion. I won't even attempt it..
