Hi Eric and Ian and Mike,
I am using a PIC16F873A, it was handy at the time.
And still no joy.
Al
This is from the from the PBP Manual
LOOKUP
LOOKUP Index,[Constant{,Constant...}],Var
The LOOKUP statement can be used to retrieve values from a table of 8-bit constants. If Index is zero, Var is set to the value of the first Constant. If Index is one, Var is set to the value of the second Constant. And so on. If Index is greater than or equal to the number of entries in the constant list, no action is taken and Var remains unchanged.
The constant list can be a mixture of numeric and string constants. Each character in a string is treated as a separate constant equal to the character's ASCII value. Array variables with a variable index may not be used in LOOKUP although array variables with a constant index are allowed. Up to 255 (256 for 18Cxxx) constants are allowed in the list.
For B0 = 0 to 5 ' Count from 0 to 5 LOOKUP B0,[“Hello!”],B1 ' Get character number B0 from string to variable B1 Serout 0,N2400,[B1] ' Send character in B1 to Pin0 serially Next B0 ' Do next character LOOKUP2
LOOKUP2 Index,[Value{,Value...}],Var
The LOOKUP2 statement can be used to retrieve entries from a table of Values. If Index is zero, Var is set to the first Value. If Index is one, Var is set to the second Value. And so on. If Index is greater than or equal to the number of entries in the list, no action is taken and Var remains unchanged.
The Value list can be a mixture of 16-bit numeric and string constants and variables. Each character in a string is treated as a separate constant equal to the character's ASCII value. Expressions may not be used in the Value list, although they may be used as the Index value. Array variables with a variable index may not be used in LOOKUP2 although array variables with a constant index are allowed. Up to 85 (256 for 18Cxxx) values are allowed in the list.
LOOKUP2 generates code that is about 3 times larger than LOOKUP. If the Value list is made up of only 8-bit constants and strings, use LOOKUP.
LOOKUP2 B0,[256,512,1024],W1
Try lookup 2, its for variables, lookup is for constants, which I assume have to be declared.
