Adding A/Ds to 12F683 in Oshonsoft
hi camerart,
I used the Post Office option to affix stamps equal to the value of £1.09 to the card they sent me and post it, I did it that way because I have not been too well over the past few days and have stayed in doors.
When and if they ever arrive I will hold them for you pending any changes.
Regards
Eric
hi camerart,
Regards
Eric
Morning Eric,
Sorry to hear that your not well. I hope your soon back to normal.
I will soon need to order electronics, and it probably cheaper for me to add extra 12F683s to the order if I need more, than for you to send them back, so you are welcome to use them if you like.
Cheers, Camerart.
Finally got your 2 12F683,s.
Placed both of them in the test jig, the LED on Pin #2 flashes when the LED on pin #5 lights!!
You must have damaged them is some way.? Do you want me to return them or bin them.?
Eric
Eric
Hi Eric,
I presume you programmed them? If not try erase then re-program. (Code from #80) I'm fairly sure that at least one was fresh, so this paragraph is not relevant.
Have you got any ideas on what I might have done to damage them?
Bin them!
Cheers, Camerart.
Yes I did reprogram the PIC's with a known working test program.
Cannot say what the damage may be.?
I could send you two of mine as replacements, if you recall I bought 6 off, which I have no immediate use for.?
Eric
Hi Eric,
Thanks for the generous offer, but they are better off there. I think you've spent enough all ready on these little tinkers, so keep them for later.
Cheers, Camerart.
