It's run at 50 hz AC, but don't follow the rest of your post. Are you suggesting that some sort of filter will be required?If it's run from 60hz AC you'll never have a problem with it conducting in the wrong direction, that's only an issue at high frequencies. Keep in mind some type of filter on the input would be recommended if not required, simply cutting half the AC cycle on a 1000watt heater will introduce massive noise on the power line.
You will only get 1/4 power it will not half the powerI am using a diode to half the power used by a 1kW AC immersion heater, do I need some sort of snubber circuit to suppress possible transients, or does the zero crossing nature of a diode make this unnecessary?
How do you figure?You will only get 1/4 power it will not half the power
Do the math for AC powerHow do you figure?
1/2 the voltage = 1/4 the power. That pesky inverse-square law again! E
I've just been playing with LTSpice. Using a diode to halve the power apparently results in ~ 43 % harmonic distortion, whereas using a lamp-dimmer set for half power (i.e. chopping off the leading half of each half-cycle) results in 95 % harmonic distortion !! You pays yer money, yer takes yer choice.But the power company won't be happy with a 500W half-cycle load since DC current tends to saturate the power transformer and it generates harmonic losses in the power line, as well a large amounts of noise due to the harmonics.
Edit: You would be better off using a lamp dimmer to reduce the power.
I hadn't thought to search for one on the net, but I doubt we'd be lucky. I like the theory, but I think it's rather academic as the resistance difference between the two methods is likely to be very small, given the thermal inertia of the heater and the thermal-insulating effect of the mineral electrical-insulator material within it.Maybe you can find a heater element model
That would only work well if both heaters were on at the same time and only if you were sharing the same phase on the same transformer......Of course, you could always persuade a neighbour to use the diode method on their immersion heater; with the diode reverse-connected, of course, to balance things out as far as the power company is concerned.
