Hi!
I'm looking for any used signal generator. But I only worked with one in university, and I'm not much into the specs.
I know some signal generator which have a 50ohm output, others have 600 ohm. 50ohm should be much better, in theory.
Also, some of them can output a variable amplitude signal between 0 and 3, 0 and 10 volts, etc... other have a DC offset, for example, 10V with 600ohm load, and 5V offset. I suppose this is worst, because you can't get 1,5V, for example... only some values are possible. For example, with a 600ohm load, only 5 to 15V would be possible.
I really don't know what to choose, but if you can give me some advices, I'll be thankful![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
