What is the current draw of the RF receiver and relay?
When do you plan on doing that test?
BTW what alec says about the voltage going high is valid so again be careful. That is if the triac goes open which it very well could. So use a cap with a significant voltage rating.
Hello,
The cap that connects to the diode in my drawing.
Absolutely not, you must use the circuit as is because that is what the test is for: to determine if the real circuit can put out any small but usable voltage when the triac is on, but see the triac being on is not the same as a switch being on. The circuit that they have designed may be able to put out some voltage even when it is turned on because it isnt turned on all the time but there may be a pause which lets some voltage get to the circuit. This is what we need to test as this could save the day![]()
Hello Ibob.
Exactly what is the project meant to do?
You have said it needs to connect to just the two wires in the light switch wiring, but can you tell more about the project?
How many lights will it switch (volts, watts) and what controls the switching? Those things will make a lot of difference to the design.
OK, based on the alec_t considerations, I've modified the circuit by adding a zenner diode and R1 (fat one).
Instead of the zenner diode I could use regulator, but I guess for the RF receiver driving a relay and the 555 IC + optocoupler elements driving the triac I don't need such, right?
Hi MrAl,
Then I guess I need to use a non-crossing zero optocoupler like MOC 3023 instead of MOC 3041 I have. 3041 is a crossing zero one.
As far as I got it this zero crossing is problem? Sorry I cannot understand exactly what problem. It did powered the TRIAC when I've tested the button solution, powering from a 12V battery.
This 555 IC is only to convert the button press to constant and vise versa, nothing else.
Maybe I should put the whole circuit diagram here so we discuss. Ohhh, so much trouble for just lighting the light..
Actually what you are saying.. the bulb will be off every half period because of this crossing zero or I cannot understand.
* The project is to have the posibility to remotely control the bulbs at the ceiling at my apartment.
* Then I will use a RF transmitter/receiver to send signal to the wall ligth switch
* The receiver needs 12V power, 6mA, I think the MOC3041 needs 15mA or so... so I need to have 12V DC inside the wall ...
