Turn on at Negative Trigger
bdiddie
Use signal wire to determine output
Here is my problem; I have a PWM signal that controls a negative trigger solid state relay to control voltage to a light source.
When the PWM signal is On-Low, it shows 0.0V and triggers the relay. At Off-High it shows 12.8V
I need an ic that will monitor the PWM signal / voltage. When input is 0.0V then output 0.0V to complete circuit. If input voltage is anything else; i.e. 1V - 11V then there will be no output. In essence I want to stop varible voltage from passing to the relay, turning it into a standard on at 0V off at 12.8V signal.
Would something like this work? NC7SZ384 - 1-Bit Low Power Bus Switch
As I said on the other forum.
Please post a schematic.
Is this what you want?
>0 output high
= 0 output low
How near zero does the voltage need to be?
There has to be a switching threshold, it could be 0V but in order for the output to be off, the input would need to be below 0V i.e. a negative voltage. So if you want 0V I suggest settling for just a bit above 0V i.e 0.1V.
Why use PWM? Sounds more like On Off keying. Agree with Hero, post a diagram.
This is actually the circuit for an automobile's daytime running lights. The wire I have circled in red is what I am trying to monitor for negative ground.
When the head lights are off the wire shows 12.8V.
DRL mode is at 70%Duty cycle so - approx 9V
When the head lights are full power wire shows approx 0.0V
So I can get by with
>0.5 output high
= 0.5 output low
This circuit detects voltages above 0.6V.
It has some hysteresis for noise immunity.
After reading my original post I guess I did clearly state what kinda circuit I need. Although my signal wire I will be monitoring is PWM, I think that is a non issue. Sorry for the inconvenience, hope I can still get a solution.
Here is what the circuit needs to consist of.
1) Signal wire
2) Battery(+) Voltage wire; (as this is automobile voltage will be between 12.5V - 14.8V)
3) Ground (I would assume!)
Here is what I need to accomplish:
Monitor "signal wire" ~~~> Voltage on this wire will be between 0.035V to 14.8(or = B+)
If signal voltage is > ≈ .75-1.0V Then
output = B+ Voltage
Else output = signal voltage
Does this make sense?
Tried a comparator yet?
1) Signal wire
output = B+ Voltage
Sorry I don't know what you mean?
What's the B+ voltage?
It's PWM, the voltage will either be nearly 0V or nearly +V. If you want to change that to different voltages, use a level shifting similar to what I posted previously.
If you want to convert the PWM to a DC voltage, use a low pass filter.
If you want to trigger an output when the PWM is above or below a certain duty cycle, add a comparator to the output of the low pass filter.
