A clamping diode is definately called for, if only for best practice, as some of my reading suggests 200V back emf on one of these relays when switched. I am not sure of the response times of an LDR but you always design for worst case. I would suggest a 1N4004 for the reasons given above.
But you must understand that normally we put the relays between collector and emitter
And is this case the protection diode will do the work. The diode will protect the BJT.
But here we have a very different situation.
1. The relay is connect between BJT emitter and the GND.
2. Also we have a fairly low resistor connect between the BJT base and the GND.
So to cut-off the BJT LDR resistor must be illuminated by a strong beam of light.
Before this happens, the current through relay coil will flow from point A to point B.
Once the transistor is at cut-off, the relay coil tries to keep the current to flow in the same direction as before. This means that the voltage at point B goes positive relative to voltage at point A
And when this voltage reach 0.7V the BJT goes into conduction mode again.
The BJT will be ON until relay coil "discharge" their energy.
Of course in real life the induce voltage will be higher then 0.7V. Simply because I ignored Rb (LDR) voltage drop.
