Have you tried buying one?- why do you imagine they are cheaper?.
They are lighter (as I've already said), but that's their only advantage.
Wasnt he talking about the *transformer* alone, not the whole microwave oven?
I got a nice one out of a big microwave a while back but have yet to rewind it.
Also, for this particular transformer, i found that they under design the primary (of course) . They dont really have enough turns for the line voltage it has to support, so there will be some near saturation in regular operation. That most likely distorts the wave shape.
Therefore i intended to us it for test equipment only not something that has to run 24/7 as it may overheat.
Welding also means you dont have to bolt it together which is the usual way if it is not welded.
Save on 4 large bolts.
Eddy currents could flow through the weld, but the cross sectional area of the weld is much less than the whole core so the current (and therefore the extra core loss) should be minimal. The reason for laminations is so that eddy currents can not flow perpendicular to the plates. If the current flowed parallel to the plates they would not do much good because they are all metal in that direction.
Butt stacks are used to keep leakage inductance higher. Interleaved laminations reduce leakage inductance, which is actually desirable in many power supply applications.
